Hello
After some tests I am concerned about my samba performance which is far from expected.
Setup. Last stock fw 3.0.0.4.385.20633, ethernet connection to a macbook pro (mojave). External disk connected to usb2. Samba defined in Asus.
My Ram with this configuration is pretty high. Around 50%.
What i observe;
1) Open a samba connection v1 via cifs://SMBHDD/Backup. I check in terminal that it is ok.
SERVER_NAME SMBHDD
USER_ID 501
SMB_NEGOTIATE SMBV_NEG_SMB1_ENABLED
SMB_VERSION SMB_1
SMB_SHARE_TYPE UNKNOWN
EXTENDED_SECURITY_SUPPORTED TRUE
UNIX_SUPPORT TRUE
LARGE_FILE_SUPPORTED TRUE
Then copy a 50MB file from macbook hdd to external disk through ASUS samba. What I see is that the first 10MB takes one second, then the next 10MB also a second. But then it slows drastically, and only increases 0.1MB every few seconds... Minutes to finish it.
2) I try the same but with samba 2: smb://SMBHDD/Backup. I check again:
SERVER_NAME SMBHDD
USER_ID 501
SMB_NEGOTIATE SMBV_NEG_SMB2_ENABLED
SMB_NEGOTIATE SMBV_NEG_SMB3_ENABLED
SMB_VERSION SMB_2.002
SMB_SHARE_TYPE DISK
SIGNING_SUPPORTED TRUE
FILE_IDS_SUPPORTED TRUE
Previously I've written [default] signing_required=no in numb.conf.
Then I copy the same file. And it does exactly the same! First 20MB in 2 seconds and then it takes forever to finish...
I have looked at the CPU and RAM usage. During the process, RAM is around 70% and CPU 1/2 are 20/80. Neither of them touches 100%.
Anyone can explain this? Why is it slowing so much? What can i try?
Thanks a lot!
What i observe;
SERVER_NAME SMBHDD
USER_ID 501
SMB_VERSION SMB_1
UNIX_SUPPORT TRUE
SERVER_NAME SMBHDD
USER_ID 501
SMB_SHARE_TYPE DISK
Thanks a lot!
