Samba recycle bin
Meecrob
I accidently deleted half of my files and found out, that its kinda hard to recover them without using recycle option in samba. After enabling the option with the following changes in smb.conf, I can't access my shares any longer. Could somebody please help me out on that? Thanks in advance!
Smb.conf:
vfs object = recycle
recycle:repository = .recyclebin
recycle:keeptree = yes
Log:
Oct 11 11:06:26 custom config: Using custom /jffs/configs/smb.conf config file.
Oct 11 11:06:28 Samba Server: daemon is started
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.476242,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]:  error probing vfs module 'recycle': NT code 0xc0000001
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.476957,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]:  smbd_vfs_init: vfs_init_custom failed for recycle
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.477231,  0] smbd/service.c:902(make_connection_snum)
Oct 11 11:10:27 smbd[2452]:  vfs_init failed for service Downloads
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.503980,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.504424,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.504689,  0] smbd/service.c:902(make_connection_snum)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.579505,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.579942,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.580210,  0] smbd/service.c:902(make_connection_snum)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.645029,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.645463,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.645730,  0] smbd/service.c:902(make_connection_snum)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.681762,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.682202,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.682473,  0] smbd/service.c:902(make_connection_snum)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.718124,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.718559,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.718855,  0] smbd/service.c:902(make_connection_snum)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.742553,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.742988,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.743255,  0] smbd/service.c:902(make_connection_snum)
Oct 11 11:10:27 smbd[2452]:  vfs_init failed for service MeeDrive
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.750798,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.751232,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.751541,  0] smbd/service.c:902(make_connection_snum)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.759934,  0] smbd/vfs.c:173(vfs_init_custom)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.760381,  0] smbd/vfs.c:315(smbd_vfs_init)
Oct 11 11:10:27 smbd[2452]: [2015/10/11 11:10:27.760648,  0] smbd/service.c:902(make_connection_snum)
I believe the version of samba installed on the router does not support the recycle bin option.
You need to delete these entries and restart the router.
No, I'm afraid not.
