Scribe scribe and Entware
cmkelley
Just a reminder since Entware recently updated, and included an update to syslog-ng, after updating Entware, it's advisable (but not mandatory) to run scribe's status function to update the syslog-ng.conf file to reflect the latest version. This can be accomplished in 3 ways:
  1. If using amtm, run scribe from amtm's menu (option 5), and select 's' (Show scribe status) from scribe's menu; or
  2. If at the command line, enter 'scribe' to run scribe, and select 's' (Show scribe status) from scribe's menu; or
  3. If at the command line, enter 'scribe status' to directly run the status, and return to the command line.
I can't think of a way to automate this when Entware updates, I really didn't expect syslog-ng to update with every Entware update when I wrote scribe.
might be overkill, but a cron job that compares the installed syslog-ng version with the config version?
or inspect which scripts/services are killed when syslog-ng updates (perhaps force a downgrade and then upgrade to test) and write a hook?
Wait a sec. This is doing what it is supposed to. We've only really seen a few relevant changes in the last few years (and they've been doozies!). So running in compatibility mode is a good fallback until we see what changes might have been made that are relevant. Blindly changing the .conf file to remove the notification is not the best thing, I think.
Also, when you do get around the fooling with scribe again, I think you only want to deal with that particular line. The sed running now changes the number in one other, maybe two places it shouldn't.
Heh, I remember people whinging when they realized almost all of the add-on scripts run every time service-event is called. I already log every call to the service-event script, nothing in the logs from updating syslog-ng earlier. It may end up having to be a cron job.
It's a catch-22, if I don't change the .conf file, people complain about it saying it's running in compatibility mode. And I can't expect people to go and manually change the configuration file version when they decide it's okay.
Actually one of the other places in the conf file I do need to change, I want to make sure the URL points to the same version as the conf file. I think I can remove the warning about time-reap now, and that will solve the other place.
Sounds like I need to make a list ...
Yeah, I think time-reap is no longer relevant for folks now. But wow it was a crazy ivan then!!
