Selective routing with pptp client?
dpjanda
Hello
Does anyone know if this is possible?
My ISP does not support OpenVPN for its VPN service.
RT-N66U
Regards to all.
I take it you are referring to the scripts that were recently posted? I will give it a go. Hope it works.
Before I start, can you or someone else tell me how to start the pptp client from a script, as it does not start on reboot.
Thanks.
create a file called openvpn-event and paste script. save the file without extension. then copy the file to /jffs/scripts folder and assign execute permission.
chmod a+rx /jffs/scripts/openvpn-event
the scripts will be executed every time you initiate a vpn connection. This is how i do it and it works great
Hi
Thanks for that, but that's not what I am looking for.
I need a way to start the PPTP client at boot. Unlike OpenVPN, there is no option to run at boot/WAN start.
That's my sticking point.
Routing wise, I have got all that. Just need N66U PPTP client to run after a reboot.
Thanks.
