services-start script help please
speedbump
I know I am missing something because I have this problem on AC68U (374.42) and N66U (35_4 sdk5). I am at a loss, any help will be appreciated.
The script will run if I manually run it but it does not auto start.
I have a copy of the file in windows, I ssh into the router, open vi, do a copy from text file and paste into the vi, save the file.
I have tried setting the sleep even to 20 and no banana.
then I do:
chmod a+rx /jffs/scripts/*
This is what I have:
admin@RT-AC68U-C378:/tmp/home/root# ls -l /jffs/scripts
-rwxrwxrwx 1 admin root 1117 May 11 20:39 services-start
file contents:
#!/bin/sh
sleep 5
echo "server=/netflix.com/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/netflix.com/54.229.171.243" >> /tmp/etc/dnsmasq.conf
echo "server=/pbs.org/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/pbs.org/54.229.171.243" >> /tmp/etc/dnsmasq.conf
echo "server=/pbskids.org/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/pbskids.org/54.229.171.243" >> /tmp/etc/dnsmasq.conf
echo "server=/bbc.co.uk/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/bbc.co.uk/54.229.171.243" >> /tmp/etc/dnsmasq.conf
echo "server=/4ondemand.com/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/4ondemand.com/54.229.171.243" >> /tmp/etc/dnsmasq.conf
echo "server=/itv.com/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/itv.com/54.229.171.243" >> /tmp/etc/dnsmasq.conf
echo "server=/youtube.com/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/youtube.com/54.229.171.243" >> /tmp/etc/dnsmasq.conf
echo "server=/hulu.com/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/hulu.com/54.229.171.243" >> /tmp/etc/dnsmasq.conf
killall dnsmasq
dnsmasq -c 1500 --log-async -n
Wouldn't this be better way:
/jffs/configs/dnsmasq.conf.add
cache-size=1500
no-poll
cache-size=1500
no-poll
What's the advantage ?
why is it better ?
why is it better ?
Using dnsmasq.conf.add will ensure that whenever the dnsmasq server is restarted, your changes will be applied to the config.
With your method, if dnsmasq gets restarted after the router has completed booting and obtaining a WAN connection, it will lose all your changes.
why is it better ?
Either will work. It just seems a lot clearer and easier to edit (less typo's). Also, you're making the changes before dnsmasq is started so you don't have to kill it and start it again. It's just more elegant IMHO.:)
+ What RMerlin said.
yea, dnsmasq.conf.add should have been my first suggestion, really. far superior method to append to the config
cache-size=1500
no-poll
OK I just tried this script and nothing worked not even google.com, it would not resolve any URL.
am I missing a trick ?
I assume that I did not need to do the chmod command as this adds to a config file.
thanks
did you move it to /jffs/configs rather than /jffs/scripts ?
I also tried to make the file executable
admin@RT-AC68U-C378:/jffs/configs# ls -l
-rwxrwxrwx 1 admin root 538 May 13 2014 dnsmasq.conf.add
and same thing. After reboot, I can not resolve any URL not the ones listed and not any other ones.
don't know what that is, I just copied the script from what you posted...
Check the content of /etc/dnsmasq.conf to ensure your entries do get appended. Also check the System Log for any syntax error message.
Thanks, the file was appended but the log did not like the line with cache-size=1500, once I removed and just left the lines with server=..... it works like a charm :-)
