services-start.sh empty
lhoekenga
The addons tab isn't showing up when I reboot my router. I'm pretty sure this problem showed up when I upgraded to 386.
This topic from last year (384.17 Addons-Menu) suggests that the presence of the addon tab is managed by /jffs/scripts/services-start.sh
services-start.sh appears to be empty..
[email protected]:/jffs/scripts# cat services-start
#!/bin/sh
Should it be? Rebooting doesn't help. Uninstalling and re-installing the add-ons help occasionally.
Liam
octopus
presence of the addon tab is managed by /jffs/scripts/services-start.sh <<<=== here is the problem
#!/bin/sh
lhoekenga
I've never looked at the directory before. Should all of those scripts have a .sh extension?
router @RT-AC88U-88E0:/jffs/scripts# ls -la
drwxr-xr-x    2 router   root             0 Jun 17 19:38 .
drwxr-xr-x   14 router   root             0 Jun 22 11:50 ..
-rwxr-xr-x    1 router   root         71139 Jun 22 11:37 connmon
-rwxr-xr-x    1 router   root           156 Jun 17 19:38 post-mount
-rwxr-xr-x    1 router   root           121 Jun 17 19:38 service-event
-rwxr-xr-x    1 router   root            11 Mar 31 14:12 services-start
-rwxr-xr-x    1 router   root        117419 Jun 22 11:39 spdmerlin
octopus
No
dave14305
Part of the Furniture
The Addons tab comes from Jack Yaz’s scripts, or the Unbound Stats GUI. Make sure all of them are up-to-date, especially Unbound if you have it installed. Most will now be mounted via the post-mount script now instead of services-start.
lhoekenga
They are all up to date. I just did a factory reset of my router and re-installed both connman and spdmerlin and will see if they remain visible.
Thanks!
