Set manual IPs via nvram (dhcp_staticlist)
xantiux
I'm trying to set the static IPs on nvram set dhcp_staticlist via a file.
I can set them fine if I pass a long string via the command, like the example below:
nvram set dhcp_staticlist="<MAC:1>192.168.3.111>Unit1><MAC:2>192.168.3.112>Unit2><MAC:3>192.168.3.113>Unit3>"
I am unable to get this to work by passing a file instead of the string. The command I'm using is:
nvram set dhcp_staticlist=/tmp/file.txt
The file contains one long string:
When I run the command above, the static IP list is cleared, and it's empty.
What am I doing wrong?
You can't "pass" anything to it. It's a variable so you can only assign a string of characters.
nvram set dhcp_staticlist="$(cat /tmp/file.txt)"
Is it possible to work around the nvram command length limitation by somehow adding new entries to the existing ones?
Or is there no easy way to append entries to the existing list?
It doesn't matter what technique you use the maximum length of that string in Merlin's current firmware is 2999 characters.
That did it!
Thank you good sir!
I found that both the NVRAM settings are required to complete the picture :):
  • dhcp_staticlist (MAC Address to IP Address) and
  • custom_clientlist (MAC Address to Client Name)
Is there any way to combine this so you can do the lot in one go?
