Setting up Entware on asuswrt
Since the root is read-only /opt is already symlinked to /tmp/opt (at least on my RT-AC66U)
So, what you need to do is symlink /mnt/sda1/asusware to /tmp/opt.
I do it in the /jffs/scripts/post-mount script. This will create the symlink if it does not exist and it will lanch the upstart scripts if the mounted device is the optware device. (Note: I have labeled the partition "optware".)
#!/bin/sh
[ ! -e /tmp/opt ] && [ -e /mnt/optware ] && ln -s /mnt/optware /tmp/opt
sleep 2s
[ "$1" = "/tmp/mnt/optware" ] && /opt/etc/init.d/rc.unslung start
Thanks Nerre, with this script it worked
#!/bin/sh
[ ! -e /tmp/opt ] && [ -e /mnt/sda1/asusware ] && ln -s /mnt/sda1/asusware /tmp/opt
sleep 2s
[ "$1" = "/tmp/mnt/sda1/asusware" ] && /opt/etc/init.d/rc.unslung start
The 2s sleep was put there because it seems as if symlinks took some time to be created. Not sure if that part could be improved. For me it just runs when I reboot the router so no big problem. I have a 5 s sleep in another script for similar purposes.
