maxbraketorque
I'm thinking about my next wifi router and trying to decide on a 3x3 or 4x4. MIMO and beamforming both require multiple antennas, but from what I've read, they use the antennas differently. As I understand it, beamforming transmits the same signal over multiple antennas with phase differences to produce constructive interference at the client. However, MIMO transmits data in parallel using multiple antennas. So if I want 2x2 SU-MIMO and beamforming, it seems to me that the wifi router needs four antennas. Is this correct, and if yes, do routers actually do this?
