Skynet always shows IPSets & IPTable Rules Failed
xmanyes
Hello,
I am experiencing Skynet problem... Tried almost everything (removed it, formated USB, make new swap, reinstall Skynet) and it still shows:
IPSets | [Failed]
IPTables Rules | [Failed]
It does whine on the locked file, but that is cleared rather quickly with hitting "r" to reload its menu, but the above 2 issues remain no matter how much time I wait...
debug info from Skynet:
Router Model; RT-AX58U
Skynet Version; v7.6.5 (28/07/2025) (36e62a220fe34ada0d4a49fb4904abfd)
iptables v1.4.15 - (eth0 @ 192.168.123.1)
ipset v7.6, protocol version: 7
IP Address; (xxx)
FW Version; 388.9_2-gnuton1 (Jun 24 2025) (4.19.183)
Install Dir; /tmp/mnt/Kingston64/skynet (51.4G / 56.6G Space Available)
SWAP File; /tmp/mnt/Kingston64/myswap.swp (2.0G)
Syslog Location; (/jffs/syslog.log) (/jffs/syslog.log-1)
Uptime; 1 days, 22 hours, 9 minutes.
Ram Available; (199M / 497M)
| Test Description | | | Result |
Internet-Connectivity | [Passed]
Public IP Address | [Passed]
Write Permission | [Passed]
Config File | [Passed]
Firewall-Start Entry | [Passed]
Services-Stop Entry | [Passed]
Service-Event Entry | [Passed]
Profile.add Entry | [Passed]
SWAP File | [Passed]
Cron Jobs | [Passed]
NTP Sync | [Passed]
Log Level 5 Settings | [Passed]
Duplicate Rules In RAW | [Passed]
IPSets | [Failed]
Local WebUI Files | [Passed]
Mounted WebUI Files | [Passed]
MenuTree.js Entry | [Passed]
| Setting | | | Status |
Skynet Auto-Updates | [Enabled]
Malware List Auto-Updates | [Enabled]
Logging | [Enabled]
Filter Traffic | [Enabled]
Unban PrivateIP | [Enabled]
Log Invalid Packets | [Disabled]
Import AiProtect Data | [Enabled]
Secure Mode | [Enabled]
Fast Switch List | [Disabled]
Syslog Location | [Default]
IOT Blocking | [Disabled]
IOT Logging | [Enabled]
Country Lookup For Stats | [Enabled]
CDN Whitelisting | [Enabled]
Display WebUI | [Enabled]
16/18 Tests Sucessful
[*] Rule Integrity Violation - [ #1 #2 #3 #4 #5 #8 #9 #10 #21 #22 #23 ]
Log of USB:
Mon Aug 25 10:47:43 DST 2025 Waited 1s for NTP to sync date
Mon Aug 25 10:47:43 DST 2025 Probing 'ext4' on device /dev/sda1
Running disk check with command 'e2fsck -p' on /dev/sda1
Kingston64: clean, 3389/3784704 files, 893547/15134716 blocks
Mon Aug 25 10:47:43 DST 2025 Disk check done on /dev/sda1
Any other clues how to start IPTables & IPSets? By the way, this worked without any problems before, but suddenly I experienced trouble from last week and wouldn't even know if my wife wouldn't tell me some of her pages didn't work (weren't blocked by skynet, just browser's https redirect rule on old http sites) and I couldn't add the domains to the whitelist on Skynet due to two errors posted above... Still can't.
