Skynet Skynet banned duckduckgo.com
eleVator
Just run into this problem, Skynet had duckduckgo.com IP banned, had to manually unban the IP in the amtm cli.
But why?
ps wrong forum, cannot delete and repost myself, sorry
But why?
Skynet uses publicly available block lists. Every once in awhile people either maliciously or inadvertently add legitimate sites to the block lists. Or sometimes shared hosts can become compromised. Or people add country block lists not realizing they would be clocking a site hosted in X region. Best bet is to lookup the blocked ip in skynet and see the reason it blocked it. You can then decide how to proceed by either whitelisting it or removing the ofending reason it was blocked.
I am a duckduckgo.com user. I see the IPv4 for duckduckgo.com was addd to the skynet whitelist. I didn't to it myself. So check Skynet for any updates.
nslookup duckduckgo.com
Server:    110.164.252.222
Address 1: 110.164.252.222
Address 1: 20.43.161.105
MatchIP 110.164.252.222
110.164.252.222 not found in AMAZON_GLOBAL
110.164.252.222 not found in NETFLIX
110.164.252.222 found in Skynet-Whitelist
110.164.252.222 not found in Skynet-Blacklist
110.164.252.222 not found in CBS_IPv4
110.164.252.222 not found in Skynet-BlockedRanges
110.164.252.222 not found in Skynet-IOT
110.164.252.222 not found in CBS_Web
110.164.252.222 not found in HULU_WEB
110.164.252.222 not found in MOVETV
110.164.252.222 not found in PANDORA
110.164.252.222 not found in DISNEY
110.164.252.222 not found in NBC
110.164.252.222 not found in ALIEXPRESS
110.164.252.222 not found in BBC
110.164.252.222 not found in LAZADA
110.164.252.222 not found in BBC_WEB4
110.164.252.222 not found in HBOMAX
110.164.252.222 not found in Skynet-Master
See this link on GitHub if you want to use the MatchIP tool.
I like this tool as well - thank you!
@Xentrk - may want to correct MatchIP’s spelling on the help menu under Usage:
MatchIP Check IP against IPSET lists to see if the IP address exists
Usage: MactchIP 111.222.333.444
purge_routes Purge policy routing rules
routes Alternative to 'ip routes' command
Makes sense, thanks.
Thanks! I see a few interesting tools there, i will have to check out later. Right now i want to let the box run for a few weeks and see how it behaves.
