Slow Bridge Speed
4glte lover
When I use the Netgear Wnr2000rpt as a wireless bridge with a cat 5e cable connected from it too an access point I get 1mbps speed and I pay for 6mbps which stays consistent. The Wnr2000rpt does get a good signal (green indicator light and connected to the main access point at 130mbps). Why does this happen? Thanks in advance for all help and suggestions.
need more specifics. your config. and needs are rather fuzzy.
The main router is a Motorola SBG6580 and the extender is a WNR2000rpt. They are using channel 6 with the second access point on 11. I am using the access point to extend the range, I know the extender can do this but it always drops the connection on my android devices. Also, the main router is set to N-Only so I have no legacy devices connected. If there is anyother information you need let me know. Thanks!
