Hello,
I've just bought RT-N66U hoping to increase transfer speeds between machines in my home network. I simply installed it leaving the majority of config options to default. Initially I used the same SSID for 2.4GHz and 5GHz bands. SSID is not hidden, wireless mode set to auto, channel bandwidth default 20/40 MHz, Authentication method is WPA2-Personal with quite a long key (34 chars). QoS is disabled by default.
Then I tested the connection between different machines using iperf (Linux and Win 7 versions). All machines within 3-5 meters from the router, not much of obstacles between them. I have one machine with Intel N 5300 card (5GHz capable) one with Intel N 6300 (5GHz capable) and two with Atheros AR9285 (2.4GHz only).
Even though it seems the cards get to high bit rate:
iperf hardly ever reaches 28Mbps usually stays ~24Mbps...
When I set separate SSIDs for 2.4GHz and 5GHz to make sure cards connect to the correct bands I can get those ~24-28Mbps. Transfers within the same band seems to be even slower.
Initially I had firmware 3.0.0.4.270 so I updated to 3.0.0.4.374_257 with no significant change.
What's the most interesting, that I can get close to 40Mbps when I test external connections with speedtest.net over those wlan links, which is the maximum connection speed for my provider... So, wlan to WAN can get almost twice as fast (or faster, at the speed of the link to the Internet is the limit here) then internally wlan to wlan.
What's wrong? What shall I change in the settings to get higher speeds?
Mode:Managed Frequency:5.22 GHz Access Point:
Bit Rate=405 Mb/s Tx-Power=15 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=56/70 Signal level=-54 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:43772 Invalid misc:628 Missed beacon:0
# iperf -c 192.168.1.224
Client connecting to 192.168.1.224, TCP port 5001
TCP window size: 21.6 KByte (default)
[ 3] local 192.168.1.50 port 43481 connected with 192.168.1.224 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 28.9 MBytes 24.2 Mbits/sec
