Slow VPN ?
VANT
Hi
Such a situation.
I ran an IPSec and Wireguard VPN server on the RT-AX86u Pro. (300/30)
I configured VPN Fusion (wireguard) on GT-AX6000 and ipsec on my laptop (1000/300)
The problem is that I only have about 30 Mbit/s over VPN for both ipsec and wireguard servers.
Why is the speed so low? Without a VPN, the speed is as ISP plan.
Hi
Such a situation.
Keep in mind that anything that goes through the VPN has to be uploaded through the server. 30 Mbps is your upload speed of the VPN server so that is your limiting factor. Using a VPN, you can never get faster than your servers upload speed.
Of course, how could I not think about it?
What does it mean when you're getting the same ish speeds but it's not your upload's fault? I have 940/940 from my ISP and get that over ethernet, but when my GT-AXE16000 is hosting a IPSec VPN, all devices that connect to it are limited to around 50/30 speeds.
Today I discovered that when there is a Wireguard connection between two ASUS routers (in my case a Zen WIFI pro ET 12 and a TUF GamingT-AX6000) and the server sides gets offline but not the fusion client, then after the server comes online again the upload speed of the client to the server get reduced by more than 50%.
Stopping and starting the client side VPN fusion connection fixes the problem. Anyone who has had the same experience.
