What client device are you using to access the router? Is the router's time zone set correctly? Does a reboot via the GUI fix the time zone discrepancy?
You may want to post a few relevant lines of your logs immediately after it has booted up to see further clues why the time is wrong (others may help with the logs you post).
A screenshot of your time zone settings may also help.
Tried another GUI reboot but same issues, it's 2 days behind
I am not sure what the relevant code is other than the first line initial clock set but here's a list of code
hope that that will do
May 9 23:30:07 ntpd: Initial clock set
May 9 23:30:07 rc_service: ntpd_synced 1724:notify_rc restart_diskmon
May 9 23:30:07 disk_monitor: Finish
May 9 23:30:07 disk_monitor: be idle
May 9 23:30:08 dnsmasq-dhcp[1359]: DHCPDISCOVER(br0) 58:2d
May 9 23:30:08 dnsmasq-dhcp[1359]: DHCPOFFER(br0) 192.168.2.
May 9 23:30:08 dnsmasq-dhcp[1359]: DHCPDISCOVER(br0) 04:cf:
May 9 23:30:08 kernel: br1: port 2(eth1.501) entered learning state
May 9 23:30:08 kernel: br1: port 4(eth3.501) entered learning state
May 9 23:30:09 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 9) Link UP at 100 mbps full duplex
May 9 23:30:09 kernel: br1: port 5(eth4.501) entered learning state
May 9 23:30:09 kernel: br0: port 2(eth2) entered listening state
May 9 23:30:09 kernel: br1: port 3(eth2.501) entered listening state
May 9 23:30:09 wlceventd: wlceventd_proc_event(559): wl0.2: Assoc 54:EF:44:36:4:9E, status: Successful (0), rssi:-69
May 9 23:30:09 hostapd: wl0.2: STA 54:ef:44:36:4:9e IEEE 802.11: associated
May 9 23:30:09 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
May 9 23:30:09 kernel: random: nonblocking pool is initialized
May 9 23:30:09 httpd: Succeed to init SSL certificate...80
May 9 23:30:09 hostapd: wl0.2: STA 54:ef:44:36:4:9e RADIUS: starting accounting session DD93071188347DE5
May 9 23:30:09 hostapd: wl0.2: STA 54:ef:44:36:4:9e WPA: pairwise key handshake completed (RSN)
May 9 23:30:09 kernel: cfg80211: Calling CRDA to update world regulatory domain
May 9 23:30:09 kernel: br0: port 3(eth5) received tcn bpdu
May 9 23:30:09 kernel: br0: topology change detected, propagating
May 9 23:30:10 cfg_server: cm_updateChanspec call wl_chanspec_changed_action
May 9 23:30:10 cfg_server: event: wl_chanspec_changed_action_a101 of eid(0) of cfgs(1473)
May 9 23:30:10 cfg_server: skip event due static chan: wl1_chanspec:165/wl2_chanspec:
May 9 23:30:10 kernel: br0: port 3(eth5) received tcn bpdu
May 9 23:30:10 kernel: br0: topology change detected, propagating
May 9 23:30:11 kernel: br0: port 2(eth2) entered learning state
May 9 23:30:11 miniupnpd[1756]: HTTP listening on port 4615
May 9 23:30:11 miniupnpd[1756]: Listening for NAT-PMP/PCP traffic on port 531
