Smb ip
stew1411
I have a RT-N16 with an external HDD attached that has all my movies. I cannot get my windows 7 PC to connect. My android tab can. On my tab, I opened the file manager, hit add server, and typed the IP. The address my tab uses is smb://192.168.2.1. It works fine. All movies stream. I cannot map the drive in windows 7 though. I've tried every variant of \\RT-N16 I can think of. FTP only let's me download files. Is there a way to connect windows 7 to the drive like I did my tab using a smb IP address?
Sent from my Venue 8 3830 using Tapatalk
In Windows, the correct UNC syntax would be like this:
\\192.168.2.1
This must be done in a File Explorer window, it probably won't work in a browser window.
\\192.168.2.1
So could I go into map network drive and do that?
Type it in to either EI or a File Explorer window (in Vista, Windows 7 or Windows 8) to verify that it works and once confirmed, you can map it then.
Once you are seeing available shares by using this URN, you can then map any network drive you wish from that window, yes.
Cool. I wasn't pointing it to the movies folder. My android tab just needed the IP and could see all folders. To map the drive, I needed to point windows to the specific folder. Thanks for the help
Sent from my SAMSUNG-SGH-I747 using Tapatalk
