SNMP on aiMesh?
vk2him
I've got two RT-AC68Us - one as main wireless router and the other as an AP - SNMP is enabled on both. I just made the AP an aiMesh node and it's working fine however I've lost access to it via SNMP - is that expected behaviour? I'm assuming the Aimesh node is still running merlin firmware - I did a restore to factory from the GUI and then searched for the node on the main router. SNMP still works ok on the main router.
This is expected.
You may be able to SSH to the Node and re enable SNMP via an NVRAM command. I’ve no idea what the variables needed would be though.
You normally edit the snmpd.conf file however it's not on the router. I could maybe manually install snmp via entware if I install amtm first, then entware?
Yep, that’ll work
Installed via opkg install snmpd and created snmpd.conf but doesn't seem to work? Is the right path /tmp/snmpd.conf ?
Not sure. Should be the same as on the main router though
Yes thats the main router location - very strange as it wont work. Also after rebooting, it cant find amtm even thought it's still installed - must lose the paths somehow
I managed to get it to work - it's different to the way the main router is setup so I had to experiment. I'll document it in case I forget in future and for others. First, install amtm then entware - that's straight forward. I installed it on a USB stick so my path to it includes the name Sandisk_USB - change this to suit your location below.
opkg install snmpd snmp-utils
Change directory to the where the snmpd script that starts/stops it resides *** change to suit your location
cd /tmp/mnt/Sandisk_USB/entware/etc/init.d
Now edit the script and note the location where the snmpd.conf file is stored:
vi S47snmpd
This is my file:
#!/bin/sh
ENABLED=yes
PROCS=snmpd
ARGS="-c /jffs/configs/snmpd.conf"
PREARGS=""
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/opt/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
Now edit the snmpd.conf file - it only needs to have basic info - this is mine:
rocommunity public
You can now start/stop/check the status of snmpd by running:
/tmp/mnt/Sandisk_USB/entware/etc/init.d/S47snmpd check
/tmp/mnt/Sandisk_USB/entware/etc/init.d/S47snmpd start
/tmp/mnt/Sandisk_USB/entware/etc/init.d/S47snmpd stop
/tmp/mnt/Sandisk_USB/entware/etc/init.d/S47snmpd restart
vk2him@RT-AC68U-DCF0:/jffs/configs# /tmp/mnt/Sandisk_USB/entware/etc/init.d/S47snmpd check
 Checking snmpd...              alive.
  • Like
Reactions: JDB
