SOLVED: Saving VPN config with router config
Luboknok
When exporting the router configuration then restoring it, the VPN configuration keys and certs are not restored, requiring I manually upload the ovpn file to each VPN slot. Is it possible to save these in the cfg export so the router restores exactly like it was saved?
What router and specific firmware are you talking about? Have you tried saving/restoring the JFFS partition?
They are stored in the JFFS partition, you have to back it up separately.
I have no control over the nvram backup, the code is closed source.
