Hello everyone
I hope someone may be able to help me as I'm at my wits end!
I have just purchased an Asus RT-AC66U router to replace my BT Home Hub, any way got it home and set it up with no real issues, but the problem came when trying to play some you tube videos on my ipad/iPhone on the app.
only some of the videos would play, at first I thought it was only under 18 videos playing so I thought it could be a parental guidance issue but I checked the router and app but they are all set up as far as I can tell correctly and as the app worked perfectly before on my home hub I assumed it was the router. I would also assume that if it was a parental guidance thing then I would get a warning on the screen?
I then played an over 18 video (not one of those ones
) which worked fine, so it seems to be only selected videos, all that happened is the video refuses to load you just get the spinning white wheel
is this a know issue or is there a setting in the router that I have to allow apps?
any advice???
Cheers Jason
any advice???
Cheers Jason
