Hello
This is the first time this has happened to me. I therefore need your expert opinions:
Router ASUS RT AC88U
Firmware asus updated
Changeover to Asus-Merlin
Firmware A-Merlin updated
Switch to dd-wrt
Firmware DD-Wrt updated
In all these steps, the installation, configuration and installation of a new firmware have ALWAYS WORK ALWAYS.
DD-wrt does not satisfy me: CPU temperatures rising, speeds fluctuating but descending in flow, vpn which lets go no connection before resuming hand.
Note, this is a finding found in asus asus-merlin and dd-wrt. A constant.
But in the scale of values, I place A-Merlin in better position than the others.
The only firmware that would have interested me to try was openwrt.
For the first time, dd-wrt is positioned as a leader and prohibits retrofitting by the firmware of A Merlin.
Question: Do you have this problem? If so, how did you deal with it?
I say again:
I'm on dd-wrt
I want to go back to asus-merlin
The default "factory" upgrade works on dd-wrt but not to install A Merlin's firmware.
I tried the method 30/30/30 no result
I noticed on various forums my surprise to see a button reset on / off (so without needle) that responded to the request while the manual and services hotline of Asus indicated that it was necessary to use a needle to reboot factory defect .
Once again the designers played a monkey trick to the engineers who took revenge lol
Thank you for your help.
Switch to dd-wrt
I say again:
I'm on dd-wrt
