Entware speedtest-netperf on AX-86U running Merlin 386.3_2 (though netperf server not stable?)
Chuckles67
I was diagnosing a poor broadband ADSL recently using a GL.iNet Mango GL-MT300N-v2GL router running openwrt, and found this command line script for assessing internet throughput and latency:
https://github.com/openwrt/packages/blob/master/net/speedtest-netperf/files/README.md
For the poor broadband ADSL I saw the ping latencies are very different during download or upload (roughly 50mS down versus 1000mS up, under network load) which was news for me - I hadn't seen asymmetrical latencies before. So then I wanted to try the same speedtest-netperf script on Merlin AX-86U which I use with broadband cable.
Using SSH to the Merlin router, here are the commands that worked for me.
# Install and permissions.
opkg update
opkg install netperf
opkg install coreutils-mktemp
opkg install coreutils-seq
opkg install procps-ng-pgrep
cd /tmp
wget https://raw.githubusercontent.com/openwrt/packages/master/net/speedtest-netperf/files/speedtest-netperf.sh
chmod +x ./speedtest-netperf.sh
# Run the speedtest.  Consider changing the netperf host server using -H option.
/tmp/speedtest-netperf.sh
Happy to see my broadband cable has similar ping latencies of 10mS during downloads and 11mS during uploads. I use Cake QoS and the reported speeds are close to the QoS bandwidth that I set.
Happy New Year folks.
UPDATE: this install may be unstable. After several successful runs of the script, I saw this warning.
WARNING: netperf returned errors. Results may be inaccurate!
I rebooted the router after running the script - the warning persisted, and removing and installing netperf didn't help. Then I tried changing the netperf server, and then test runs with netperf-west and netperf-eu are successful, e.g.:
# Successful.
/tmp/speedtest-netperf.sh -H netperf-west.bufferbloat.net
# Successful.
/tmp/speedtest-netperf.sh -H netperf-eu.bufferbloat.net
# Not successful.
/tmp/speedtest-netperf.sh -H netperf-east.bufferbloat.net
Perhaps the netperf servers are not stable.
