Setting up new Asus RT-AX88U Pro.
Advanced, Wireless tab < 2.4g, create ssid and key, go to 5g, create different ssid and different password, go back to 2.4 to check key, stays the same, then go to 5g to check the key and it changes to the key that was used for the 2.4g.
This is on a new router, sent first one back because of this, and the second does the same thing.
Only does this with asus stock firmware, not with asuswrt merlin.
Smart connect disabled.
Hitting apply after change.
Asus Stock Firmware < Version 3.0.0.6.102_33352
Asuswrt-Merlin < Ver.3004.388.8.4
