Hello All,
I'm having a weird issue with the wireless log I was wondering if others had seen as well.
Let's say I have a DHCP LAN reservation for 192.168.1.100 and 192.168.1.10.
Let's say 192.168.1.100 = hostname A and is wired
Let's say 192.168.1.10 = hostname B and is wireless
The wireless log will show the correct wireless MAC for hostname B but the hostname hostname A.
Example:
MAC ADDRESS OF HOSTNAME B - IP ADDRESS - HOSTNAME A
This also happens with something like 192.168.1.5 and 192.168.1.50
The hostname doesn't match the wireless MAC address.
Basically, the wireless MAC appears to always be correct, however the hostname is a complete crap shoot depending if a similar ending octet IP is used.
(192.168.1.100 & 192.168.1.10; 192.168.1.2 & 192.168.1.20; 192.168.1.3 & 192.168.1.30, etc..)
EDIT: I'm running the N66U on 3.0.0.4.372.31. This issue was present in all past FW I can recall.
Example:
