System Log
Logi
Every time I check the System Log I always find the same messages (many more, I just copied 3 of them), is this a normal behavior? I am running the latest Merlin FW 380.58, thanks
Mar 26 08:20:34 kernel: DROP IN=eth0 OUT= MAC=aa:bb:cc:dd:ee:ff:gg:hh:ii:jj:kk:ll:mm:nn SRC=xxx.yyy.zzz.www DST=xxx.yyy.zzz.www LEN=115 TOS=0x00 PREC=0x20 TTL=56 ID=7219 PROTO=TCP SPT=443 DPT=62156 SEQ= ACK= WINDOW=430 RES=0x00 ACK PSH URGP=0 OPT ()
Mar 26 08:20:35 kernel: DROP IN=eth0 OUT= MAC=aa:bb:cc:dd:ee:ff:gg:hh:ii:jj:kk:ll:mm:nn SRC=xxx.yyy.zzz.www DST=xxx.yyy.zzz.www LEN=115 TOS=0x00 PREC=0x20 TTL=58 ID=56104 PROTO=TCP SPT=443 DPT=62070 SEQ= ACK= WINDOW=363 RES=0x00 ACK PSH URGP=0 OPT ()
Mar 26 08:20:35 kernel: DROP IN=eth0 OUT= MAC=aa:bb:cc:dd:ee:ff:gg:hh:ii:jj:kk:ll:mm:nn SRC=xxx.yyy.zzz.www DST=xxx.yyy.zzz.www LEN=108 TOS=0x00 PREC=0x20 TTL=51 ID=901 PROTO=UDP SPT=4500 DPT=1024 LEN=88
NOTE: I have replaced the SRC, DST and MAC data with dummy information.
its look like its related to Firewall, but im not sure.
Have you tried to Hide them until someone have a better answer
http://192.168.1.1/Advanced_DHCP_Content.asp
Hide DHCP/RA queries
It helped, now I am getting much less, but I am still seeing multiple messages many times every minute:
Mar 26 17:29:16 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:29:23 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:33:30 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:33:58 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:34:01 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:35:23 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:35:58 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:36:55 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:36:59 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:37:01 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:37:05 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:37:11 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:37:28 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:39:47 kernel: DROP IN=eth0 OUT= MAC=
Mar 26 17:40:09 kernel: DROP IN=eth0 OUT= MAC=
What is the value of SRC=xxx.yyy.zzz.www.
It looks like you are being scanned from outside which is quite normal. Probably China or Shodan.
It also looks like you have enabled logging of dropped packets (Firewall - General > Logged packets type)
Have you enabled Web or SSH access from the WAN (Administration > System)?
Both SSH and WAN access are Disabled.
What should be the correct (default) value for Logging Dropped Packets?
Some of the SRC address are:
- 216.58.216.110
- 216.58.192.174
- 208.54.73.77
- 17.110.227.101
- 17.143.163.228
- 17.143.164.81
- 172.217.3.78
- 17.143.163.228
- 17.143.164.81
- 190.166.17.119
- 93.174.93.50
- 108.168.169.76
Any comment or advice is welcome, thnaks
We'd have to see the complete unedited log entries to have a complete understanding. But it just looks like the normal internet "noise". I wouldn't worry about it as you haven't opened any services to the WAN.
Change "Logged packets type" to None otherwise you can expect your syslog to be full of this "noise".
17.110.227.101 Apple Inc
17.143.163.228 Apple Inc
17.143.164.81 Apple Inc
93.174.93.50 Quasi Networks LTD
108.168.169.76 John W, 185 Madison Avenue
172.217.3.78 Google Inc
190.166.17.119 CODETEL.NET.DO
208.54.73.77 T-Mobile USA
216.58.216.110 Google Inc
216.58.192.174 Google Inc
Thank you very much, the "internet noise" is gone after setting the log to NONE
