The 5G radio signal turn off sometimes
adrianmak
My router is AC87U, firmware 378.55
I used inssider to look around wifi devices. Only ME has a 5G signal router.
I found that the 5G signal turn off sometimes. I have to reboot the router to get it on again.
Have you tried Merlins latest code for the 87U ? If not you may want to give it a try it has a new driver for the 5G quantenna chip set that may resolve your 5Ghz issues.
Summary of changes since 378.55:
  • Merged with Asus GPL 378_9177, which includes numerous fixes and tweaks, and improvements to the networkmap. This includes the newer Quantenna driver for the RT-AC87U, which resolves connectivity issues on the 5 GHz band, however it still causes some battery drain on that band. The only workaround is to revert to 378.55 if this is a problem for you.
  • Support was added for the (unreleased yet) RT-AC88U. Thanks to Asus for providing a development sample.
  • Enhancements to syslog handling. The default log level can now be configured (it used to be hardcoded to Emergency). This is especially useful to users who log to a remote syslog server.
  • Editable entries for the DHCP static lease, virtual servers and prot triggers pages.
  • Various component updates: miniupnpd, openvpn, dropbear and minidlna were updated to their latest versions.
  • Various issues related to networkmap were resolved, especially handling of long hostnames.
  • You can now configure up to five separate OpenVPN clients, to match Asus's stock FW.
  • Numerous other fixes, please see the complete changelog for details
Okay. I will take a try.
Should I reset the factory default after firmware upgrade ?
Since My ip subnet is different than the factory 192.168.1.X
Mine is 192.168.103.X
For each factory reset, I have to plug my PC to router directly to access the router setting page.
I would for sure preform a full factory reset this is always a good idea when there is a driver upgrade.
I had the same issue on 378.55. Testing on 378.56 now to see if the issue persists.
1 day in. No issues so far! But my 5ghz issue occured only about 1 week+ into leaving the router turned on.
