The dreaded "All download attempts failed" on amtm first run
treefu
Hello,
I've been through a few other posts from users that have had this problem and mine doesn't appear to be cert or DNS related.
ASUSWRT-Merlin RT-AX86U 3004.388.9_2 Mon Apr 28 21:28:05 UTC 2025
admin@RTAX86U:/tmp/home/root# amtm
_____________________________________________
 Initializing amtm for first run
 Getting from fwupdate.asuswrt-merlin.net
 ! Module amtm.mod download failed
 ! using fallback server diversion.ch
 All download attempts failed,
 exiting amtm now.
 Check that both domains properly resolve
 on this router:
 - fwupdate.asuswrt-merlin.net
 - diversion.ch
So, checking the domains are in the DNS cache:
admin@RTAX86U:/tmp/home/root# nslookup fwupdate.asuswrt-merlin.net
Server:    8.8.8.8
Address 1: 8.8.8.8 dns.google
Address 1: 104.21.28.144
Address 2: 172.67.170.222
Address 3: 2606:4700:3035::ac43:aade
Address 4: 2606:4700:3037::6815:1c90
and the drive is mounted correctly:
admin@RTAX86U:/tmp/home/root# mount
ubi:rootfs_ubifs on / type ubifs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=466864k,nr_inodes=116716,mode=755)
proc on /proc type proc (rw,relatime)
tmpfs on /var type tmpfs (rw,relatime)
tmpfs on /tmp/mnt type tmpfs (rw,relatime,size=16k,mode=755)
sysfs on /sys type sysfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
ubi1:data on /data type ubifs (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
/dev/mtdblock9 on /jffs type jffs2 (rw,noatime)
/dev/mtdblock9 on /rom/etc/ssl/certs/ca-certificates.crt type jffs2 (rw,noatime)
/dev/sda on /tmp/mnt/sda type ext4 (rw,nodev,relatime,data=ordered)
And finally that the USB drive is mounted correctly and writeable:
admin@RTAX86U:/tmp/home/root# touch /tmp/mnt/sda/test.txt
admin@RTAX86U:/tmp/mnt# ls -lh /tmp/mnt/sda/
drwx------    2 admin root       16.0K Jul  5 18:14 lost+found
-rw-rw-rw-   1 admin root           0 Jul  5 18:41 test.txt
HOWEVER, if I manually try to curl to the update server:
admin@RTAX86U:/tmp/home/root# curl -kv https://diversion.ch/amtm_fw/amtm_rev
*   Trying 80.74.145.140:443...
* connect to 80.74.145.140 port 443 failed: Connection timed out
* Failed to connect to diversion.ch port 443 after 15035 ms: Couldn't connect to server
* Closing connection
curl: (28) Failed to connect to diversion.ch port 443 after 15035 ms: Couldn't connect to server
Can anyone tell me what I'm missing please?
All the best and thanks
amtm has literally just been updated. It may just be a case of waiting a small while for the files to be available on the servers.
Let me summon @thelonelycoder
This looks damn unusual. What else is installed on your router?
Connection works fine for me in the USA.
Upload new versions to my server takes seconds and is done before I post an update. My server is fine and serving.
I added that in there, following one solution suggesting it was a certs issue, from the threads I linked to above.
I removed the mount entry and rebooted, but it didn't make any difference.
I see the recommended way to remove amtm is with amtm. But it won't run.
Hmm.
Try:
rm -fr /jffs/addons/amtm
It persists in /usr/sbin.
admin@RTAX86U:/tmp/home/root# rm -rf /usr/sbin/amtm
rm: can't remove '/usr/sbin/amtm': Read-only file system
Of course, that file is a stub that's part of the firmware. It can't be removed. When you first run it it downloads the current version into jffs. Delete the files in the directory I said.
I appreciate your efforts, but it doesn't change the outcome.
Edit: Just tried it again and it works now! Many thanks.
I'm mystified. The stub failed on first run but now works.
eConnah Solved CakeQOS not limiting download Asuswrt-Merlin AddOns 14
