Time to replace an RT N66U
PartisanEntity
Hi all,
I have been using an Asus RT N66U router for a long time now and would like to get a replacement.
We have a 2 story apartment. and several devices (PCs, Playstation, cell phones, tablets).
I would like to stick with Asus. What would be a good replacement? Maybe something in the upper mid-range?
Thanks in advance for your suggestions.
Hi all,
I did the same 6 months ago. Replaced my good old RT-N66U after almost 7 years service with RT-AX88U. It is really excellent router and the most important - it has full support by @RMerlin.
Which one might depend on how things are going with your N66U. If you're having a few minor coverage/range/performance issues you might want to step up to an AC86U. If not you can save a few bucks with an AC68U. If your wife doesn't like the multi-horned alien look you could even try a Blue Cave (no Merlin).
Moving from WiFi 4 to WiFi 5 is significant, WiFi 6 is still uh optional.
I'd look for a Merlin-compatible unit with as many spatial streams as possible (higher receive gain, for more usable throughput over distance, even with 2x2 clients).
First choice would be an RT-AX88U. If you'd rather keep it under $200, then go RT-AC86U.
The RT-AC88U has been superseded by both the RT-AC86U and the RT-AX88U.
I could not suggest the RT-AC88U as a good buy today.
