Tor Settings
bkz81
Hello
I am running 378.55 on the N66U. I wanted to find out for the tor settings section do those ports need to be changed? Also what does Redirect all user from (LAN Br0) mean?
LAN is the network and Br0 is the WAN port
so basically all its saying is that everything on the network will get directed to Tor.
Or you can have specific mac address's that will go through Tor.
I would think you should leave the other settings as default. I am not expert with Tor, but I would think when you enable Tor server other people can pass data through your Tor server. I don't know if I would want that on my router :p
