Traditional QOS, what is the default class?
Allan Marcus
hi,
I’m new to ASUS routers. I’m trying to set up traditional QOS, and I’m a little confused. If I make a few rules that cover most of my traffic, what happens to the traffic not covered by an explicit rule? What is the fallback default rule?
Or should my final rule simply cover all traffic so I can set a default?
Also, is there anyway to reorder the rules, or do I have to delete then and reenter?
You want to use Fresh JR’s QOS script. Have a search for it.
Explains how it all works and let’s you change it all
Thanks. I’ve been reading up on that script.
With traditional qos fixed, I’m inclined to start simple with a qos rule to prioritize the Ooma as highest, the bit torrent client as lowest, and hope the rest falls into a default. I just need to know what that default is.
If I need to us JRs script to get there, I will. I was just hoping to keep it simple.
P.s., I’ll be installing the Merlin firmware soon (after a family trip next week).
Default class is defined by the qos_default nvram setting, which by default I believe is "lowest".
Trial and error leads me to this conclusion:
highest = 0
high = 1
medium = 2
low = 3
lowest = 4
Yes, correct!
highest = 0
high = 1
medium = 2
low = 3 (default)
lowest = 4
Thanks,
Vanic
