trouble getting services-start to work
bigjohns97
Just a nix noob here trying to learn the ways of the command line, I had previously had this small script working that would enable the 252 option of dhcp to keep my windows 7 box from always searching for a proxy address and now i have updated to the newest beta of the merlin build and it doesn't seem to be working anymore.
#!/bin/sh
echo "dhcp-option=lan,252,"\n"" >> /tmp/etc/dnsmasq.conf
killall dnsmasq
dnsmasq -c 1500 --log-async -n
I reboot my router and check the dnsmasq.conf and the dhcp option isn't in there.
is this a possible permission issue since the script was built with a previous version of firmware?
Why not use a custom config file instead? The firmware will automatically do everything for you.
Enable JFFS, then create /jffs/configs/dnsmasq.conf.add, with just the line you wish to add. The firmware will automatically append it to the generated dnsmasq.conf each time it creates it, before starting dnsmasq.
Well crap, aren't i glad i started this thread, that is way simpler.
thanks rmerlin!
Is there somewhere i could look to find all of these tricks i might be missing out on?
thanks rmerlin!
The README included with the firmware actually contains information on every feature/changes done to the firmware vs the original FW. The Wiki on Github also contains various tutorials and tricks (see the sticky post in this forum).
Is that what those are for? :)
Pretty cool stuff never had a router with this kind of power, per ip network stats is pretty cool as well.
While we've had fairly advanced firmwares for years with Tomato and DD-WRT, the RT-N66U is probably the router that truly unlocked that potential, thanks to its fast CPU and large amount of both flash and RAM.
