Trouble with Google Pixel wifi connection RT-AC3100 and log flood 382.1_2
unrealdude24
The wifi seems to be working and other devices are connected. My Pixel phone will connect and work fine for a day and then refuse to connect at some point. The entry for the wifi will go into disabled state in Android due to no longer working. In the system logs I see this on repeat:
Feb  3 23:38:40 kernel: CONSOLE: 105485.344 wl1.0: wlc_probresp_send_probe_resp: wlc_frame_get_mgmt failed
Feb  3 23:38:41 kernel: CONSOLE: 105486.344 lb_alloc: req_size: 866 hnd_pktid_free_cnt: 253 OSL_MEM_AVAIL: 8048
Feb  3 23:38:41 kernel: CONSOLE: 105486.344 wl1: wlc_frame_get_mgmt: pktget error for len 866 fc 50
Feb  3 23:38:41 kernel: CONSOLE: 105486.344 wl1.0: wlc_probresp_send_probe_resp: wlc_frame_get_mgmt failed
Feb  3 23:38:42 kernel: CONSOLE: 105487.344 lb_alloc: req_size: 866 hnd_pktid_free_cnt: 253 OSL_MEM_AVAIL: 8048
Feb  3 23:38:42 kernel: CONSOLE: 105487.344 wl1: wlc_frame_get_mgmt: pktget error for len 866 fc 50
Feb  3 23:38:42 kernel: CONSOLE: 105487.344 wl1.0: wlc_probresp_send_probe_resp: wlc_frame_get_mgmt failed
Feb  3 23:38:49 kernel: CONSOLE: 105494.344 lb_alloc: req_size: 866 hnd_pktid_free_cnt: 253 OSL_MEM_AVAIL: 7952
Feb  3 23:38:49 kernel: CONSOLE: 105494.344 wl1: wlc_frame_get_mgmt: pktget error for len 866 fc 50
Feb  3 23:38:49 kernel: CONSOLE: 105494.344 wl1.0: wlc_probresp_send_probe_resp: wlc_frame_get_mgmt failed
Once I restart the router, it will connect again and continue functioning until this problem arises. Smart Connect is enabled with all default settings. I can help debug and collect more logs if needed.
Google knows about this bug, and they're pushing out a patch to fix it.
