Hello,
I recently installed 3 pairs of of the ScreenBeam MoCA adapters (5 adapters installed + 1 spare), configured Network Privacy, ip addresses through DHCP on the same LAN as the network I wanted to extend. They have been working fine overall l without major issues.
However, today, out of the blue, one of the adapters (the one that is connected to the network switch that provides access to most of the devices I want to connect) stopped working (The coax cable light turned off). (The other 4 adapters had both LEDs on).
First I thought, something was wrong with the coax cable this adapter was using (which I had replaced today as well). However, after getting a different cable, and power cycling the adapter, I couldn’t get it to work and connect to the other ones (coax cable light to light up).
I then started power cycling the rest of the adapters (one at a time). At first, each adapter wouldn’t join back to the Network (coax light off) after I turned it off and back on, until I power cycled one of the adapters (which happened to be the last one to power cycle), and then all of them started working right away.
This made me come up with the following questions:
- What made this happen? (I am concerned because if this happens again, everything will stop working until I manually power cycle all of them, not reliable).
- How can I prevent this from happening again?
- Is there a good wat to monitor or troubleshoot issues?
- Do these adapters have a CLI?
Thanks.
Thanks.
