Solved Trying to install 'locate' but failing to add group mlocate
  • Thread starter Thread starter MvW
  • Start date Start date
M
MvW
Guest
I'm trying to install locate, following these instructions which seem to have worked by executing
opkg update
opkg install mlocate
Before I can use it, I have to make sure the database is filled, but when running
updatedb
it is complaining:
updatedb: can not find group mlocate[/CODE}
To add a group 'mlocate' with the appropriate permissions, I need the package 'addgroup' or 'synogroup' (as suggested alternative) alternative, but both are apparently not available in entware-ng.
Anyone have any pointers how to create the appropriate group? The instructions are not for Merlin but for Padavan, but looking at them, I can hardly image this coudn't be achieved on Merlin as well. Or am I too positive?
You need to add the user mlocate to the group file under /etc in order to use the updatedb command.
You can achieve this by creating a group.add file under jffs > configs, with the content mlocate:x:666: . This way, whenever you reboot your router, user mlocate will be added to the group file and you won't need to add again manually.
Image for reference:
Great solution. I couldn't achieve what I wanted with findutils-locate but with your solution locate from the package mlocate it works like a charm. Thanks for the suggestion!
But now I get erros logged due to the 'changed group file':
crond[4365]: / etc / group: bad record (needed to put spaces in the path due error from forum software)
Removing the group.add and just changing the permissions on the database folder: chmod +rw /opt/var/mlocate - did not help...
Any other solution?
Any other solution?
Are you invoking mlocate via cron? If so, does mlocate work from the command line?
Any other solution?
Try replacing the "x" with an "*".
mlocate:*:99:
mlocate:*:99:
@ColinTaylor : I get the error message every 2 minutes - yes, this looks like a cron job, but not initiated by me - maybe a kind of watchdog for the group file...
@underdose : Well as it's looking that the "watchdog" is complaining about group file modification, this might not be a solution... but I will check this later.
Update:
Yes, the star (*) made the difference: Using same format als the other entries in the group list works fine!
