TX RX Asus router
tiomiguel
WHat is the exact meaning of this? TX/RX shown is about the router or the client? 1 Mbps rate means the client is able to receive less than can transmit (6,5 Mbps)?
In other words, the client is receiving worse than transmitting?
I have read clients transmit worse than router. I do not understand these numbers
Those numbers will fluctuate. View them while the device is actually transmitting or receiving and see what the values are.
Rate drops to 1 Mbps while in power saving mode. It will rise once there is actual traffic.
For 2.4Ghz - the 11b/g/n/ax lowest rate is 1 Mbps - disable legacy and we move it to 6 Mbps..
An idle client that is attached, will drop down to basic rates..
I have an RT-AX88U Pro, upgraded from RT-AX86U, I've checked the disable 11b box on both routers and changed to N only through different firmware versions but a quick network scan show 11b always being broadcast. Is this a known bug?
