unable to play iptv directly via `udp://...` since turned on dot service
NewUserHa
merlin version: 386.3_2
before:
able to playing via udp://...
able to playing via http://.../udp/... from proxy
playing udp://.. while htpp://.. is already playing will cause http one stop.
playing http://.. while udp://.. is already playing seems fail(if remember correctly)
now:
Unable to playing via udp://...
playing http://.. while udp://.. is already playing will block and return `[ffmpeg] http: Stream ends prematurely at 0, should be 18446744073709551615 Failed to recognize file format.`
the only settings changed is dhcp server adress and dot(it was turned of by default)
anyone has any idea? is it a bug?
