Gary_Dexter
If setup correctly, Unbound will also update the cache in the background via the prefetch setting
Is anyone even bothered by the idea that — for unknown reasons — you’re forced to serve expired DNS records to maintain an artificial cache hit rate?
Why aren’t these records refreshing themselves?
Yes.I'm not using unbound, but I have one question.
Does dnsmasq also has a DNS cache?
For clarity, (From the docs @ https://unbound.docs.nlnetlabs.nl/en/latest/manpages/unbound.conf.html# ):IIRC - unbound has a tunable parameter for the TTL limits and cache...
cache-min-ttl: (value in seconds)
The default is 0 (zero) which is what the domain owner has intended...
cache-min-ttl: <seconds>
Time to live minimum for RRsets and messages in the cache.If the minimum kicks in, the data is cached for longer than the domainowner intended, and thus less queries are made to look up the data.Zero makes sure the data in the cache is as the domain owner intended,higher values, especially more than an hour or so, can lead to trouble asthe data in the cache does not match up with the actual data any more.
Default: 0 (disabled)
In the end, we all just come back to vanilla, because tweaking is always breaking things. lolP.S.
I did warn you ... this is the entrance to the 'Rabbit hole' !!!
Spoilsport !!!!In the end, we all just come back to vanilla, because tweaking is always breaking things. lol
Indeed - but some are going to do it anyways...n the end, we all just come back to vanilla, because tweaking is always breaking things. lol
what is your output for unbound -V ?This is my config - albeit on a RPi - but it works flawlessly
# https://nlnetlabs.nl/documentation/unbound/unbound.conf/
server:
# Do not daemonize, to allow proper systemd service control and status estimation.
do-daemonize: no
# A single thread is pretty sufficient for home or small office instances.
num-threads: 4
# Logging: For the sake of privacy and performance, keep logging at a minimum!
# - Verbosity 2 and up practically contains query and reply logs.
verbosity: 0
log-queries: no
log-replies: no
# - If required, uncomment to log to a file, else logs are available via "journalctl -u unbound".
#logfile: "/var/log/unbound.log"
# Set interface to "0.0.0.0" to make Unbound listen on all network interfaces.
# Set it to "127.0.0.1" to listen on requests from the same machine only, useful in combination with Pi-hole.
interface: 127.0.0.1
# Default DNS port is "53". When used with Pi-hole, set this to e.g. "5335", since "5353" is used by mDNS already.
port: 5335
# Control IP ranges which should be able to use this Unbound instance.
# The DietPi defaults permit access from official local network IP ranges only, hence requests from www are denied.
access-control: 0.0.0.0/0 refuse
access-control: 10.0.0.0/8 allow
access-control: 127.0.0.1/8 allow
access-control: 172.16.0.0/12 allow
access-control: 192.168.0.0/16 allow
access-control: ::/0 refuse
access-control: ::1/128 allow
access-control: fd00::/8 allow
access-control: fe80::/10 allow
# Private IP ranges, which shall never be returned or forwarded as public DNS response.
# NB: 127.0.0.1/8 is sometimes used by adblock lists, hence DietPi by default allows those as response.
private-address: 10.0.0.0/8
private-address: 172.16.0.0/12
private-address: 192.168.0.0/16
private-address: 169.254.0.0/16
private-address: fd00::/8
private-address: fe80::/10
# Define protocols for connections to and from Unbound.
# NB: Disabling IPv6 does not disable IPv6 IP resolving, which depends on the clients request.
do-udp: yes
do-tcp: yes
do-ip4: yes
do-ip6: no
# Ratelimiting
ratelimit: 1000
ratelimit-size: 8m
ratelimit-slabs: 8
ratelimit-factor: 10
ip-ratelimit: 100
ip-ratelimit-size: 8m
ip-ratelimit-slabs: 8
ip-ratelimit-factor: 10
jostle-timeout: 1000
# Defend against and print warning when reaching unwanted reply limit.
unwanted-reply-threshold: 10000
# Set EDNS reassembly buffer size to match new upstream default, as of DNS Flag Day 2020 recommendation.
edns-buffer-size: 1232
# Maximum UDP response size (not applied to TCP response).
# Suggested values are 512 to 4096. Default is 1232. 65536 disables it.
max-udp-size: 1232
# Increase incoming and outgoing query buffer size to cover traffic peaks.
so-rcvbuf: 4m
so-sndbuf: 4m
# Hardening
harden-glue: yes
harden-dnssec-stripped: yes
harden-algo-downgrade: yes
harden-large-queries: yes
harden-short-bufsize: yes
harden-below-nxdomain: yes
harden-referral-path: yes
aggressive-nsec: yes
deny-any: yes
# Privacy
use-caps-for-id: yes # Spoof protection by randomising capitalisation
rrset-roundrobin: yes
qname-minimisation: yes
minimal-responses: yes
hide-identity: yes
identity: "Server" # Purposefully a dummy identity name
hide-version: yes
# Caching
cache-min-ttl: 3600
cache-max-ttl: 86400
serve-expired: yes
serve-expired-ttl: 86400
serve-expired-ttl-reset: yes
serve-expired-reply-ttl: 30
# serve-expired-client-timeout: 1800
prefetch: yes
prefetch-key: yes
msg-cache-size: 128m
rrset-cache-size: 256m
key-cache-size: 8m
neg-cache-size: 8m
# the number of slabs to use for cache and must be a power of 2 times the
# number of num-threads set above. more slabs reduce lock contention, but
# fragment memory usage.
msg-cache-slabs: 8
rrset-cache-slabs: 8
infra-cache-slabs: 8
key-cache-slabs: 8
# Faster UDP with multithreading (only on Linux).
so-reuseport: yes
# Should additional section of secure message also be kept clean of unsecure
# data. Useful to shield the users of this validator from potential bogus
# data in the additional section. All unsigned data in the additional section
# is removed from secure messages.
val-clean-additional: yes
# Disable subnetcache to circumvent warnings
# related to prefetch and serve-expired
# when ECS is compiled with Unbound.
module-config: "validator iterator"
# Enable extended statistics.
extended-statistics: yes
statistics-interval: 0
# Use libevent
outgoing-range: 8192
num-queries-per-thread: 4096
# fast-server-permil: <number>
# Specify how many times out of 1000 to pick from the set of fastest
# servers. 0 turns the feature off. A value of 900 would pick from
# the fastest servers 90 percent of the time, and would perform nor-
# mal exploration of random servers for the remaining time. When
# prefetch is enabled (or serve-expired), such prefetches are not
# sped up, because there is no one waiting for it, and it presents a
# good moment to perform server exploration. The fast-server-num op-
# tion can be used to specify the size of the fastest servers set.
# The default for fast-server-permil is 0.
fast-server-permil: 750
# fast-server-num: <number>
# Set the number of servers that should be used for fast server se-
# lection. Only use the fastest specified number of servers with the
# fast-server-permil option, that turns this on or off. The default
# is to use the fastest 3 servers.
fast-server-num: 3
# target-fetch-policy: <"list of numbers">
# Set the target fetch policy used by unbound to determine if it
# should fetch nameserver target addresses opportunistically. The
# policy is described per dependency depth.
# The number of values determines the maximum dependency depth
# that unbound will pursue in answering a query. A value of -1
# means to fetch all targets opportunistically for that dependency
# depth. A value of 0 means to fetch on demand only. A positive
# value fetches that many targets opportunistically.
# Enclose the list between quotes ("") and put spaces between num-
# bers. The default is "3 2 1 0 0". Setting all zeroes, "0 0 0 0
# 0" gives behaviour closer to that of BIND 9, while setting "-1
# -1 -1 -1 -1" gives behaviour rumoured to be closer to that of
# BIND 8.
target-fetch-policy: "0 0 0 0 0"
Not sure why you guys dig a hole when >99% cache hit rate with constant performance is on the surface and doesn't require any 3rd party firmware, Entware, 3rd party scripts, USB sticks or additional hardware. Some are doing it for sports, I guess.![]()
Some like to over complicate things with hacky workarounds in hot pursuit of that edge case. Or they are just waiting for you to hand out the sports medalsNot sure why you guys dig a hole when >99% cache hit rate with constant performance is on the surface and doesn't require any 3rd party firmware, Entware, 3rd party scripts, USB sticks or additional hardware. Some are doing it for sports, I guess.![]()
Some like to over complicate things with hacky workarounds in hot pursuit of that edge case. Or they are just waiting for you to hand out the sports medals.
Tuning unbound cache (or any cache) is often a case of diminishing returns. Once you're:
- hitting >99%,
- seeing consistent latency,
- avoiding eviction storms or slab rebalancing issues.
Some individuals will just never be satisfied until they squeeze every last drop of performance --- just ask @Viktor Jaep before your choose which pill to take.
Running the version available form Debian APT repository so only version 1.17.1 - will be upgrading to the latest release soon though.what is your output for unbound -V ?
dietpi@dietpi:~$ sudo unbound -V
Version 1.17.1
Configure line: --build=aarch64-linux-gnu --prefix=/usr --includedir=${prefix}/include --mandir=${prefix}/share/man --infodir=${prefix}/share/info --sysconfdir=/etc --localstatedir=/var --disable-option-checking --disable-silent-rules --libdir=${prefix}/lib/aarch64-linux-gnu --runstatedir=/run --disable-maintainer-mode --disable-dependency-tracking --with-pythonmodule --with-pyunbound --enable-subnet --enable-dnstap --enable-systemd --with-libnghttp2 --with-chroot-dir= --with-dnstap-socket-path=/run/dnstap.sock --disable-rpath --with-pidfile=/run/unbound.pid --with-libevent --enable-tfo-client --with-rootkey-file=/usr/share/dns/root.key --disable-flto --enable-tfo-server
Linked libs: libevent 2.1.12-stable (it uses epoll), OpenSSL 3.0.17 1 Jul 2025
Linked modules: dns64 python subnetcache respip validator iterator
TCP Fastopen feature available
BSD licensed, see LICENSE in source package for details.
Report bugs to [email protected] or https://github.com/NLnetLabs/unbound/issues
unbound -V
Version 1.23.1
Configure line: --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --prefix=/usr --includedir=/usr/include --mandir=/usr/share/man --infodir=/usr/share/info --sysconfdir=/etc --localstatedir=/var --disable-option-checking --disable-silent-rules --libdir=/usr/lib/arm-linux-gnueabihf --libexecdir=/usr/lib/arm-linux-gnueabihf --disable-maintainer-mode --disable-dependency-tracking --disable-rpath --with-pidfile=/run/unbound.pid --with-rootkey-file=/var/lib/unbound/root.key --with-pthreads --with-ssl=/root/build-openssl+quic --with-libevent=/usr --with-pythonmodule PYTHON_VERSION=3.9 --with-dynlibmodule --with-pyunbound PYTHON_VERSION=3.9 --with-libexpat=/usr --with-protobuf-c=/usr --with-libsodium=/usr --with-libmnl=/usr --with-libbsd=/usr --with-libnghttp2=/usr --with-libngtcp2=/root/build-openssl+quic --enable-largefile --enable-dnscrypt --enable-tfo-server --enable-tfo-client --enable-event-api --enable-subnet --enable-dnstap --enable-cachedb --enable-ipsecmod --enable-ipset --enable-gost --enable-ecdsa --enable-dsa --enable-ed25519 --enable-ed448 --enable-sha1 --enable-sha2 --enable-systemd --with-chroot-dir= --with-dnstap-socket-path=/run/dnstap.sock --libdir=/usr/lib --disable-flto LDFLAGS=-Wl,-rpath -Wl,/root/build-openssl+quic/lib -Wl,-O1 -latomic
Linked libs: libevent 2.1.12-stable (it uses epoll), OpenSSL 3.0.16+quic 11 Feb 2025
Linked modules: dns64 python dynlib cachedb ipsecmod subnetcache ipset respip validator iterator
DNSCrypt feature available
I hope you are not mixing the Red and the Blue pills ...
We use essential cookies to make this site work, and optional cookies to enhance your experience.
