Unbound low cache hit rate
For me, I was getting unbound hit rate from 30%-35% to 65%-75% once I made this change. Remove any upstream server from Cloudflare, quad9, and etcs from Adguad Home. Just include the unbound ipv4 and ipv6. For DoT, I just enabled on unbound end.
127.0.0.1:53535
tcp://127.0.0.1:53535
[::0]:53535
tcp://[::0]:53535
[/f.e.4.5.0.c.1.5.2.0.7.1.0.0.6.2.ip6.arpa/][::]:553
[/router.asus.com/][::]:553
[/www.asusnetwork.net/][::]:553
[/www.asusrouter.com/][::]:553
[/use-application-dns.net/][::]:553
[/dns.resolver.arpa/][::]:553
[/lan/][::]:553
[//][::]:553
Just add serve-expired-client-timeout: 0 to unbound and the hit rate jump up too 95%. what the hack.
After researching some more:
From this post: https://github.com/NLnetLabs/unbound/issues/1175
serve-expired-client-timeout: 1800 is the default for unbound. The line does not exist in the configure file.
I use a good Samsung SSD in an enclosure and USB3. I also have ipv6 turned off so I'm not sure if that makes any difference.
I am sure it the same millisecond since the client only requests either ip4 or ipv6, whichever preferred by the device.
If it doesn’t exist in the config with anything other than the default value, it will be active still (with the default value).
I rem out that line. While the cache performance number is expressed, I tend to gear to unbound recommend setting. Took a little page from your config such as num-thread and the 4 stacks line.
I'm not using unbound, but I have one question.
Does dnsmasq also has a DNS cache?
Slightly off-topic, but dnsmasq has its own equivalent to Unbound's:
serve-expired-ttl: 86400
which is:
use-stale-cache
(it defaults to 86400 seconds)
I tried this out of curiosity and the hit rate went from ~30% to ~80%. But that's very much dependent on the sort of traffic your network generates. I'm looking at you, Ubuntu Server 👀and your endless connectivity checks.
I am getting a really tiny hit rate under 10% with PiHole->Unbound, both are running on the router. Does this seem reasonable?
admin@RT-AC86U-9988:/# unbound -V
Version 1.23.0
