Hi all, just upgraded ax6000 to 3006 without any issue. Not really a pro here but need some help trying to set up the guest network for IOT.
In 3004, I had already setup guest network for iot and restrict access to intranet. I did not create a vlan so I’m not sure if it’s on a separate vlan.
After upgrading to 3006, I notice this iot said is on a separate vlan (which is good as that’s what is intended right?).
Question then would be, do I need to re setup the guest network or just stick to the current?
I also saw in the new guest network pro, there is this option “different subnet “. What’s the difference between subnet and vlan?
My goal here is to have iot on a separate ssid that have no access to the main network. Yes I know some iot needs to be in the same (vlan?subnet?), for casting etc. in which case, I will move those to the main network.
Thanks.
Thanks.
