unexpected token `foreign'
satxtreme
Pls help me solved.
/./configure: line 2256: syntax error near unexpected token `config.h'
././configure: line 2256: `AM_CONFIG_HEADER(config.h)'
Makefile:3772: recipe for target 'libxml2/stamp-h1' failed
make[3]: *** [libxml2/stamp-h1] Error 2
make[3]: Leaving directory '/home/satxtreme/asuswrt-merlin/release/src/router'
Makefile:202: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/home/satxtreme/asuswrt-merlin/release/src-rt-6.x'
Makefile:2822: recipe for target 'bin' failed
make[1]: *** [bin] Error 2
make[1]: Leaving directory '/home/satxtreme/asuswrt-merlin/release/src-rt-6.x'
Makefile:2892: recipe for target 'rt-ac66u' failed
make: *** [rt-ac66u] Error 2
You will have to provide more details as to what you are compiling, how you are compiling, and on what OS you are trying to compile.
That old legacy code has been abandoned two years ago, and you are also trying to compile using a distro that was never tested. You need specific autoconf versions for the build process to succeed - check what's documented in the Wiki, and see if your distro offers alternate packages with these older versions.
