Jim Jaggger
Hello,
I'm a little stuck. I have an ASUS AC88U router connected to a Virgin Hub 3.0. This has been working really well and I've received speeds of 211/11. However, because my house has thick walls, I don't get much internet connectivity at the back of it. I therefore bought an ASUS PL-AC56 (powerline network). It seemed fairly easy to set up and I can now receive stable speeds of 40/11 via the wired connection that comes from the powerline adapter (in a separate room).
The powerline connection seems to be stable. It doesn't drop out or lose connectivity. However, my original wired connection (PC plugging straight into my router) now regularly drops connection.
Has anyone else experienced this? If I unplug the ethernet cable that connects the router to the powerline adapter the connectivity problems cease and my base PC is back to normal. However, I obviously can't then connect the PC in the other room.
Does anyone have any advice for this? I would really appreciate your help. I'm a bit of a novice in terms of wifi connectivity but I'm a keen learner and I'm learning fast.
Thanks in advance for your help
Jim
Jim
