Upgrade to Wifi6?
yugi
My current setup which includes Netgear R8500 (main), R7000 (wired AP), AC2100 (wired AP), RT-AC1900P (AP, connected in a barn via powerline Zyxel PLA6456 G.hn Wave 2) and it's quite stable. However, 2 latest firmware updates for R8500 had DNS resolving issues, so I'm staying with older firmware, which don't have any issues. All the routers are quite old, around 3-6 years old. Should I upgrade to Wifi6? I'm looking at buying used Netgear RAX80 or RAX200 main and 2 EAX80 APs. I like Netgear's hardware, the software is a bit dated, but it meets my needs so far.
Upgrade = yes
Netgear = no
AP's I would recommend using the Zyxel NWA210AX 4x4 radios or the NWA110AX 22 radios $160 / $130
You only need 1 router and it doesn't have to have WIFI built in which just means adding 1-2 more AP's which levels the pricing. You can get a wired router w/o wifi for $50.
I got away from Netgear and all other prepackaged setups for the reasons you listed with fixing one thing and breaking another in the process. It got time consuming to fix their F up every time they released new FW.
Here's a snap of the AP dashboard. Off to the left you have the options for performance / configuration / etc.
I setup the AP's in stand alone mode to not have to deal with the Nebula "service" to manage multiple AP's. You can power them from either AC or POE which is nice if you don't have an outlet handy where you want to place it. They made some strides in the FW to make them more stable as well in recent months. I think I've seen 3-4 FW updates in the past couple of years whereas Netgear probably released 10-15 updates.
You also get 8 SSID's per band and if you're doing VLAN's you can choose up to 4000+ to use.
No one has the answer to this question, but you. I would remove the mix of home routers as and build a centrally managed Wi-Fi system, perhaps TP-Link Omada as excellent price/performance SMB hardware. We have discussed similar Wi-Fi 6 setup in another thread just few days ago:
This may give you some ideas for better hardware than home routers. I personally use 4x AC Wave 2 AP's and have no intention to upgrade.
I have Cisco PIX-506 laying around, but it's very old.
Not good anymore. If you want to keep user friendly home router interface with many features, you can use RT-AC1900P as wired router running FreshTomato (mainly for VLAN's support) or Asuswrt-Merlin (for TrendMicro AiProtection/Adaptive QoS, custom scripts). The router is fast enough for 300Mbps ISP line with no NAT acceleration (incompatible with some FreshTomato/Merlin features) and Gigabit capable with NAT acceleration enabled. The CPU is the same as in Netgear R8500 - Broadcom BCM4709C0 1.4GHz dual-core. It is very reliable router and still actively supported.
I was using it as a main router with Merlin software before I bought R8500, and R8500 greatly improved internet throughput compared to AC1900P. Right now R8500 handles 300/300 Mbps internet connection with no issues. I've also got RAX20 for free, but I can't seem to make it's wireless work. It appears for short time, then disappears. Was planning to test Wifi6 with it.
Yes, when the radios are enabled. The older BCM4360 in AC1900P use more CPU. R8500 has newer BCM4366 radios with own processing unit. When used as wired routers though the two will be the same. Anyway, one of the two is good enough to be used as main router - you have a choice. A new AP's system can take care of your Wi-Fi needs. You can upgrade the components separately after. Home routers are AIO disposable devices.
The upside of the NWA is you have a 2.5GE uplink compared to 1GE and port sharing on the "node". It's funny how it can do 6gbps but only 1gbps port to go anywhere else besides itself.
It can't do 6Gbps, it's only theoretical. Realistically with 2x2 client, you can do 1200 Mbps, and probably even lower.
This is the link speed, the throughput is lower, unless 160MHz channel is used.
Like most home routers, nothing new or surprising. AX11000 class routers come with Gigabit ports.
It can connect faster with wireless backhaul, theoretically it can reach 4.8 Gbps router to router.
Ok, then you're limited to your WAN port which these days is either 1gbps or 2.5gbps unless you're investing in something more than a home router.
So, you see how if you follow the path from Client to WAN you have several roadblocks to getting your true potential speed.
