VLAN hybrid mode
max95
My ISP uses the following setup:
IPTV is in a VLAN with the id 295 and internet traffic is untagged.
When I go to IPTV settings and select manual and set the IPTV VID to 295 and leave the internet and VoIP blank, TV works but internet not. The menu doesn't let me set the VID to 0 ...
Is it possible to set up only 1 VLAN for IPTV on one port, and untagged packets to the other 3 ports?
would setting other ports' VID to 0 solve the issue?
How could I achieve it?
I looked over telnet and found vconfig, which allows me to create a virtual interface on a real interface, but how to assign it to a single port?
from what I concude from ifconfig eth3 is the WAN port and eth2 is the LAN with a switch. I saw no changes in ifconfig, when I set the VLANS in the web interface .....
max95
