VLANs for VIVO ISP in Brazil
Yar Surus
Hello!
First of all, thanks a lot for the Merlin wrt. It's awesome and it keeps the good layout of the original wrt.
I found this forum, while pursuing a solution for replacing the ISP's router with my ASUS RT-AC66U (or even my old N56U).
Point is, I need to be able to configure 3 VLANs:
VlanName ID/Priority
Internet 10/0 (PPPoE)
IPTV 20/3 (ENET ECAP) - manual setting static IP, DNS, MASK and Gateway
VOIP 30/5 (ENET ECAP) - manual setting static IP, DNS, MASK and Gateway
A conditional DHCP pool based on VENDOR ID: "MSFT_IPTV" that will delegate specific DNS servers to those STBs (matching the vendor ID)
>> A static lease should also work, but the specific DNS server must be assigned.
And routes.
Such as:
# Destination IP // Gateway // Subnet Mask // Metric
1 172.28.0.0 // 10.180.128.1 // 255.252.0.0 // 1
I believe, that the MOVISTAR TRIPLE VLAN profile in the IPTV tab settings have most of these configurations already built in (VIVO and MOVISTAR both belong to TELEFONICA). If I could just adapt these settings into a new profile "VIVO BRAZIL", you'd be saving a lot of frustrated people from the stock router and its subpar performance!!!
Thanks again
Hello!
And routes.
Such as:
Thanks again
Maybe someone could just show me how to see those configs and change VLANs ID/PRIORITY over telnet :)
Movistar have triple vlans but you still need to enter the internet and tv vlan "code" in the provided lan box.
try doing it with vivo brazil.
im no expert but i thought vlans was all about the vlan "code"?
My set up has the tv decoder set with static details inside.
internet 6
tv 2 in the lan iptv section.
microsoft rc****
and botht eh igmp boxed activated.
