Voip delay cutting time
Damit1
Hi
So I am using voip, and recently moved from one company to another.
In both companies, once the adaptors were behind NAT -outbound call delayed in about 10 sec.
Port forwarded to 5060.
Once you DMZed the adaptors it got faster to about 5 sec, but if I compare it to using app in the smartphone, still slower.
Any idea why is it happen?
What can I do to shorten the delay time ?
Thank you
did you try Advanced Settings > WAN > NAT Passthrough
RTSP Passthrough - Disable.
SIP Passthrough - Disable.
not sure if this will have any effect
The 5 sec delay probably has nothing to do with your internet connection but with the dial string used.
Since you are not using VoIP phones but an adapter there is no 'dial' or 'send' button so the adapter figures out when you are done dialing and when to start the call...
If this is a managed VoIP adapter talk to the folks that manage it and see if they can setup a faster dial string for countries with fixed length phone numbers (like NANP)
If it's your own adapter try to find a forum for it and look for instructions on how to optimize the dial string.
The longer delay on NAT is strange but maybe related in a way that the provider expects a SIP proxy or STUN settings and those are not configured correctly and they somehow have a fallback method to figure out how to get you connected and it just takes time to kick in...
It is actually the opposite, RTSP passthrough and SIP passthrough are enabled plus NAT Helper
Why should I disable them? sounds like the opposite result to happen.
Did some changes to the NAT settings in my adaptor, that cut the times to 5 sec.
Changed to NAT UPNP and cut it to half.
It is might be correct and it is abut the dial plan that makes it longer time to 5 sec.
Thanks!
For sure turn those off. They interfere with SIP being setup on VoIP. I have been on VoIP for 15 years and anytime the ALG's are on it messes it up. It also matters how you have your adapter setup to discover your public IP. I am on a Lynksys adapter and it has 8 different settings that can be changed to discover the IP with or without using a STUN server. Here is a shot of mine.
You can also set up your dial plan to eliminate the need to dial local area codes or prefix numbers. My calls go thru in less than a second.
Disabled SIP and RTSP.
How do I make a dian plan in grandstream?
Looking for such thing existing and not finding anything
Got a headache already
So I see nothing on router side, only Adaptor?
BTW
SIP ALG disabled just longer the delay to 13 sec and nothing else.
Enabled back and everything is OK.
So thanks for the time being
This is the wrong place to ask about your adapter. Use the grandstream forums to get expert help there. People there can help you with the best settings.
Have you tried using the providers dial plan?
