VPN and connection management in general
I can't think why the first command would run but the second wouldn't.
By the way, you still haven't fixed the quotation mark error.
cru a VPN_Failover "*/5 * * * *" /jffs/scripts/VPN_Failover.sh 1 once #VPN Failover
should be
cru a VPN_Failover "*/5 * * * * /jffs/scripts/VPN_Failover.sh 1 once" #VPN Failover
should be
The quotation mark error I corrected immediately. However everything works correctly
should be
You were right on the first command, I took it off. It can create problems on startup.
