VPN question
Diveblaster
Hi
First I thank you so much for your work Merlin.
I have just 4 simple questions regarding VPN setup. Im using RT-AC66U with ur latest firmware 380.58.
In the picture beneath i circled the sentences.
What does the following mean and when do I use them to get things working?
1. Push LAN to Clients
2. Direct clients to redirect Internet traffic
3. Respond to DNS
4. Advertise DNS to clients
Regards
Dive
Push a route to the VPN clients so they know to use the VPN tunnel to be able to remotely access a device on your LAN through their IP.
As it says, it tells connected clients to use the VPN tunnel for all Internet traffic.
3. Respond to DNS
Allows clients to connect to the DNS server that runs on the router, so they can, for example, resolve hostnames of the LAN devices.
Tell the clients the IP address of the router that they can use as a DNS server.
Push lan to clients, see http://www.snbforums.com/threads/prevent-lan-access-from-openvpn.20058/#post-144944
Direct clients to redirect Internet traffic, see http://www.snbforums.com/threads/op...nnection-for-remote-support.11552/#post-72081 (you would set this to yes only if you were, for example, connected to a remote public wifi and wanted to browse the Internet safely by setting up a secure vpn tunnel back to your router and then come (unencrypted) back out onto the Internet. So all your traffic from your client to your home router is encrypted.)
Respond to DNS, see http://www.snbforums.com/threads/asuswrt-merlin-3-0-0-4-374-38-is-out.14691/page-14#post-98877
Advertise DNS to clients - I can't find an explanation from Merlin on this one, but I think it means tell the remote, vpn-connected clients to use the home router for any DNS queries.
EDIT: Well you now have the definitive answer on ALL the options.
Ty both for a splendid answer.
Most humble Dive
Yes. Thanks for an excellent question, and answers of course.
Further to the original posters questions perhaps the settings listed below can be explained further as I found no information to allow me to understand what they do.
Interface type = if I choose TUN and then select Respond to DNS enabled will VPN clients be able to resolve hostnames on the network or will I still have to use TAP instead in order to resolve hostnames when on VPN
Protocol = UDP or TCP?
Firewall = Auto, external only or Custom? What do they do
Manage Client-Specific Options = What do the various options do
Thanks very much
For TUN vs. TAP and the differences/benefits - check link below;
https://community.openvpn.net/openvpn/wiki/BridgingAndRouting
As for TCP vs. UDP - there are valid applications for both - TCP has a bit more overhead, but on a noisy/lossy link, TCP has the advantage.
As for the other items, it boils down to what the desired goal is - whether you're bridging two sites, or providing remote access into the LAN.
