VPN Security
ROJO
IS and IPSec point-to-point VPN setup with VPN hardware on both ends of the connection more secure than a SSL VPN setup?
thiggins
Mr. Easy
Staff member
No. Depending on the encryption used and the strength of the keyphrase or authentication method, they can be equally secure.
YeOldeStonecat
The decision between them is more on deployment and management, rather than a security competition. IPSec is still the standard for tunnels between hardware appliances, which gives the best performance. SSL is fast growing as the preferred method for the "road warriors" to remote in...ease of deployment, less IT support costs and time invested.
Although one can claim that a default setup for router to router VPN tunnel could potentially be a more wide open door for a problem, versus a stand alone SSL remote VPN client. Because another PC on the remotes host network, if infested with a worm that can spread across IP ranges...could shoot through that tunnel.
