VPN simple question first.
BigTony
Newbie here. Ive got 3 Asus AX6600 routers in a mesh setup driven by Starlink Internet. I'm adding a VPN. Question is which of the routers does the VPN get installed on? Is it the "master" or the first one in the sequence? How do I tell as the dashboard does not identify where the VPN is? And should I care? I think I do as 2 are wired and the third is wireless.
I'm assuming you're talking about a VPN client rather that a VPN server?
In either case the VPN must be on the AX6600 that is configured as the gateway router. I'm assuming your other two AX6600's are just access points (AiMesh nodes).
