VPNMON VPNMON-R3 v1.5.0 -Aug 3, 2025- Monitor OpenVPN/Wireguard WAN/Dual-WAN Health & Reset Multiple Connections (Available in AMTM!)
Fixed the "FAILOVER" message and corrected spacing
@Viktor Jaep
Phew! My anxiety levels have noticeably eased! :)
Random thought ... now I have Server List Automation going thanks to the superb work by @iTyPsIDg is it possible to retrieve the WG Client "Description" field and have the NordVPN server number added in to the "City Exit / Time" column as well as the City? For example my WG slot is currently auto-labelled "Sydney #876".
So instead of currently saying "Sydney: 0d 01h:19m" for me it would say "Sydney #876: 0d 01h:19m" or the like for example?
Clumsy Mockup ...
But you may be running out of horizontal space a bit I guess if location is long ... and that may lead to OCD issues!
@Viktor Jaep
Clumsy Mockup ...
As much as I would like to extend the screen space, the description field could be any length depending on what the person decides to put there. For instance, my OVPN clients all have "VPN1 - 125.215.36.75 added by VPNMON-R3" in their client description. Right now, I've got my curl query pumping out "Cityname WG #NORD#", but I'm thinking of changing it to "Country City WG #NORD#" for even more detail. But it could literally be anything that the person between the keyboard and the chair thinks up. I do like providing that accurate city name based on the Public IP exit. One hopeful way to at least give you a compromise on this is that the log does include the description field. So you can at least see it there? Would that suffice?
Going to cautiously say that we can call this a "beta" now... so opening it up to those who want to experiment with something that's pretty darn close to production now. ;)
What's new?
v1.5.03b - (TBA)
- PATCH:
Fixed the numbering for the WG slots to reflect 6-0 to provide standardization across the script when referring to the use of these slots. Thanks to @CaptainSTX!
- PATCH: Fixed the Skynet import logic and some of the on screen/log language to reflect "WG" terms instead of "VPN".
- PATCH: Fixed the WG Client Slot Server List Maintenance page to accurately display the first value (Connection Description) in a comma-separated list.
- PATCH: Clarified the "Number of Available OVPN/WG Client Slots" menu item under the config, to bring more understanding that (2) is strictly for older routers who can only have a max of 2 OVPN client slots at any given time, but also don't have any native WG capability without the help of 3rd party scripts. The (5) option provides capabilities for 5 x OVPN and 5 x WG client slots, as available on most (if not all) newer routers running the later versions of the Merlin FW.
Download Link:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/VPNMON-R3/develop/vpnmon-r3.sh" -o "/jffs/scripts/vpnmon-r3.sh" && chmod 755 "/jffs/scripts/vpnmon-r3.sh"
Significant Screenshots:
Our main house network is now using WG Slot 2 full-time for all their needs, using one of 2203 randomized NordVPN WG server connections, while VPN slot 5 still provides an Unbound DNS VPN exit giving our internal WG clients some DNS privacy. All is working well! :)
This all has made me just realize that RTRMON needs some work done to include the Wireguard connections now. Grr. :mad:
Yes, that will indeed be helpful I think - thanks @Viktor Jaep!
Yep, that's exactly the conundrum! ;)
I like that idea. I'll start looking at this. 👍
One more thing to consider is on the configuration menu where you set number of VPN slots change the description to make it clear that option 1 is referring to OPEN VPN slots only since on some routers you can have up to 10 clients.
Really? What routers allow more than 5 VPN clients? Thanks for this... I'll work on more clarifications!
5 OPEN + 5 WG on my AX88 Pro just my suggestion that you indicate the choice 1 - 5 applies only to OPEN VPN clients. At some point in distant past Merlin's firmware limited the number of Open VPN clients on older routers and if I remember correctly those routers didn't support WG clients or at least without some scripting.
Gotcha Yeah, with that choice I'm assuming 5 ovpn and 5 WG slots. The older routers could only support 2 x ovpn and had to make effort to get WG working like you said. I'll make it more clear. Thank you!
Here's what I came up with, @CaptainSTX ... let me know if you think this helps clarify:
Running the latest beta, wondering the time isnt working on mine, any ideas?
You can initialize the time by resetting your VPN connections within VPNMON. So, hit 1 and then 3.
It would also work by doing a daily scheduled reset. 🙂
it came up saying NEW in green- but nothing yet is showing up for time...
Oh my bad. You need to enable monitoring using (M) for those 2 slots first.
Gotcha, I was wondering why I didnt have any "X" markings under that tab.... lol
Thank you its working now
BTW, congrats on using an Unbound over VPN connection... I don't come across many of you! I think it's one of the coolest things since sliced bread! :)
