WAN disconnection problem
Cwelle
Hello guys,
can someone tell me why am I getting these every 2 days?
May 10 22:00:01 dnsmasq[15092]: read /etc/hosts - 5 addresses
May 10 22:00:01 dnsmasq[15092]: read /etc/hosts.dnsmasq - 10 addresses
May 10 22:00:01 dnsmasq-dhcp[15092]: read /etc/ethers - 10 addresses
May 10 22:00:01 dnsmasq[15092]: using nameserver 212.186.211.21#53 for domain upc.at
May 10 22:00:01 dnsmasq[15092]: using nameserver 195.34.133.21#53 for domain upc.at
May 10 22:00:01 dnsmasq[15092]: using local addresses only for domain home
May 10 22:00:01 WAN Connection: ISP's DHCP did not function properly.
May 10 22:00:01 DualWAN: skip single wan wan_led_control - WANRED off
May 10 22:00:01 stop_nat_rules: apply the redirect_rules!
May 10 22:00:04 rc_service: udhcpc 19497:notify_rc start_firewall
May 10 22:00:04 dnsmasq[15092]: read /etc/hosts - 5 addresses
May 10 22:00:04 dnsmasq[15092]: read /etc/hosts.dnsmasq - 10 addresses
May 10 22:00:04 dnsmasq-dhcp[15092]: read /etc/ethers - 10 addresses
May 10 22:00:04 dnsmasq[15092]: using nameserver 212.186.211.21#53 for domain upc.at
May 10 22:00:04 dnsmasq[15092]: using nameserver 195.34.133.21#53 for domain upc.at
May 10 22:00:04 dnsmasq[15092]: using local addresses only for domain home
May 10 22:00:05 start_nat_rules: apply the nat_rules(/tmp/nat_rules_vlan2_vlan2)!
May 10 22:00:05 wan: finish adding multi routes
May 10 22:00:05 rc_service: udhcpc 19497:notify_rc stop_upnp
May 10 22:00:05 rc_service: waitting "start_firewall" via udhcpc ...
May 10 22:00:06 rc_service: udhcpc 19497:notify_rc start_upnp
May 10 22:00:06 rc_service: waitting "stop_upnp" via udhcpc ...
May 10 22:00:06 WAN Connection: WAN was restored.
May 10 22:00:07 ddns update: ez-ipupdate: starting...
May 10 22:00:07 ddns update: connected to dynupdate.no-ip.com (8.23.224.120) on port 80.
May 10 22:00:08 ddns update: request successful
May 10 22:00:08 ddns update: asusddns_update: 0
May 10 22:00:08 ddns: ddns update ok
May 10 22:00:08 dhcp client: bound xxx.xxx.xxx.xxx via 84.113.167.1 during 345600 seconds.
Every 2 days at around 22:00 WAN gets reconnected (Internet stops working for a short time) and I get those lines in general log.
I am using RT-AC87U with Merlin firmware 380.59_beta2. WAN lease time is 4 days.
I tried other firmware versions (Merlin and Asus).
WAN Connection Type: Automatic IP.
DHCP query frequency: Aggressive Mode.
I appreciate any help that you can provide.
Flash the 380.59 final and do a full reset to factory defaults followed by a minimal and manual configuration of the router to secure it and connect to your ISP.
http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
You may also want to turn off all network equipment after having performed the above and physically unplug all devices from the AC power too for 30 minutes to an hour or more.
Then,
Plug in the modem (wait 5 minutes).
Plug in the router (wait 5 minutes).
Plug in any switches you may have.
Turn on any wired devices (computers, NAS, etc.).
Turn on your wireless clients.
Be wary of using the very latest Asus firmware as it may prevent you from flashing other firmware to test with.
I was getting hit by this error several times a day after a recent firmware upgrade. Once I changed the DHCP query frequency -> Normal Mode, the errors went away. The default for me was Aggressive Mode prior.
